It is currently Tue Aug 25, 2026 1:27 am
 Post subject: Dumb question....
PostPosted: Tue Apr 22, 2003 5:43 pm
How much oil do you put in the Z28 LS1 when changing? The manual says something about 5 liters. Seems too little for me.
Thnx.
R@M
Got boost?
PostPosted: Tue Apr 22, 2003 6:07 pm
Hm, not really a good comparison, but the 5.7 in my '79 took about 4.5l (from empty) ...
PostPosted: Tue Apr 22, 2003 6:34 pm
Just took a look at my Haynes manual... LS1 is 5.5qts, LT1 5qts ... 5.5 converts to about 5.2 Litres ...
PostPosted: Tue Apr 22, 2003 7:27 pm
If you also change the filter, I am pretty sure it is 6 qts, which is close to 6 liters. I recommend that you put in 5, start the engine and let it build up pressure, and check for leaks. Then shut it down and check the oil level. I always buy 6 qts.
PostPosted: Tue Apr 22, 2003 7:43 pm
Haynes states "with oil filter change" ... !?
PostPosted: Wed Apr 23, 2003 4:35 am
Rampage,
Garry is right, it is 5.5 quarts with the filter change.
PostPosted: Wed Apr 23, 2003 8:54 pm
5.2 litres rings a bell
Z be dead.
