It is currently Mon Aug 24, 2026 3:02 pm
 Post subject: Driveshaft work
PostPosted: Wed Jan 28, 2004 11:24 pm
Looking for any place, within a reasonable distance from K-Town, that can shorten and re-balance a driveshaft for my 78.
Barry
77 Trans Am
78 Camaro
81 Corvette
86 Trans Am WS6
2001 Trans Am WS6
2010 H-D Softail Custom
2011 Charger R/T
2018 Ram Power Wagon
PostPosted: Thu Jan 29, 2004 5:58 am
Oh I see how it is- only come around here when you want something. mmm, hmm! :o
Just kidding, but the place on the way to Sembach can do pretty much all car related things.
PostPosted: Thu Jan 29, 2004 2:06 pm
Where at? I might need to have mine shortened in my '57.
PostPosted: Thu Jan 29, 2004 6:41 pm
The phone # is 06303-806451
Be sure and tell him Jack sent you! ;)
PostPosted: Thu Jan 29, 2004 10:28 pm
I'm surprised I posted here too...I usually don't get a reply...unless it's from you or Garry.
I've heard differing opinions of the Sembach place, but I guess it's worth a try.
Barry
77 Trans Am
78 Camaro
81 Corvette
86 Trans Am WS6
2001 Trans Am WS6
2011 Charger R/T
PostPosted: Fri Jan 30, 2004 4:21 am
They just rebuilt my LS1, and it runs better than new. I recommend them. Just don't rush them and they will do it right.
PostPosted: Fri Jan 30, 2004 6:57 pm
Gives me more confidence . Thanks, Jack. I'll give them a ring. They obviously speak English....?
The reason for the driveshaft is to put a 700R4 in my 78 Z behind the 383. I should be more worried about finishing the engine.
3:73 gears + 350TH = shitty gas mileage.
Barry
77 Trans Am
78 Camaro
81 Corvette
86 Trans Am WS6
2001 Trans Am WS6
2011 Charger R/T
PostPosted: Fri Jan 30, 2004 9:27 pm
A 200R4 will not require a new driveshaft. The overdrive ratio is slightly higher (700=.70, 200=.67) and it can be built up to handle over 550hp. Bolts right up as long as you get a dual bolt pattern bellhousing. The other is B.O.P. only. Less crossmember mods needed as well...
