It is currently Mon Aug 24, 2026 12:50 pm
 Post subject: Brake Hardware Loose
PostPosted: Thu Jun 17, 2004 1:39 pm
Has anyone had one of their brake brackets come loose? The caliper is tight and snug, but for some reason, the thin metal bracket that holds the brake pad has become loose :? ... I can still brake no problem, just when I hit a bump I hear it rattle... very annoying :evil: ... I tried to see if I could get in there and tighten it somehow, but there is nothing to tighten... anyone have any ideas??
1998 Chameleon Z28 A4
K&N Air Filter w/FRAM
Borla Catback Exhaust
SLP Level One Suspension Kit
NGK TR55s w/ Taylor Thundervolt Wires
PostPosted: Thu Jun 17, 2004 1:49 pm
Hmm. got me on that one. I'd have to see that personally. Never heard of that before.
PostPosted: Thu Jun 17, 2004 4:50 pm
Locktight might work, but to answer the original question, no I have ever heard of that happening.
PostPosted: Thu Jun 17, 2004 5:07 pm
Are you sure your brakes are working properly? I think it might be one of two things; either you need to tighten that bracket (there are two bolts on each side, holding them on), or you need to bleed your brakes! I'm pretty certain those are the only two things that could be wrong! ;)
PostPosted: Fri Jun 18, 2004 5:00 am
sounds from the description , it is the pad shim also known as the ant sqeal shim. if it is detached , stick it back on with high temp silicone . or throw it out and use the silicone the back of the pad.
PostPosted: Fri Jun 18, 2004 8:26 pm
I know the brakes are working because I have roughly the same wear on both sides... I found this pic and modified it to identify the metal bracket I am talking about...
Is that the shim you are talking about Roy?
PostPosted: Sat Jun 19, 2004 4:24 am
pict ure doesn't work
PostPosted: Sat Jun 19, 2004 4:28 am
That is an anti squeal shim for OEM pads. Put a little silicone on it to secure it and keep it from rattling.
PostPosted: Sat Jun 19, 2004 11:31 am
geocities doesn't like to allow the pics to be linked
just right click on the X and select properties copy the url and then paste it into a new window
PostPosted: Sat Jun 19, 2004 2:40 pm
Here is a link to the pic:
http://www.geocities.com/r1996_z28/index.html
PostPosted: Wed Jun 23, 2004 9:09 am
You da man Roy! ;)
