It is currently Tue Aug 25, 2026 12:39 am
 Post subject: LS6 Intake
PostPosted: Thu Jun 17, 2004 1:21 pm
Who makes the best after market LS6 Intake?
PostPosted: Thu Jun 17, 2004 5:39 pm
If you have EGR and want to use it with the LS6 intake manifold I would say SLP is a good address. :)
PostPosted: Thu Jun 17, 2004 6:41 pm
Get the FAST intake manifold. It can be ported to flow match a good set of heads. You can also get the Holley, which can also be ported and polished to a chrome like finish! Those are much better options for someone who wants a performance gain. I don't think anyone makes an aftermarket LS6 intake, anyway! ;)
PostPosted: Thu Jun 17, 2004 7:13 pm
Your car came from the factory with the LS6 intake already on it. If you want an aftermarket intake that flows better than get the FAST intake but if you haven't done a cam & head upgrade your throwing away $$$$$
PostPosted: Thu Jun 17, 2004 7:59 pm
That is true, but you will see a partial gain with it.
PostPosted: Thu Jun 17, 2004 10:45 pm
I agree Jack.......but for the money he could do a cam and pick up alot more HP.
 Post subject: LS6
PostPosted: Fri Jun 18, 2004 7:28 am
Ok, I have a normal 2001 Trans AM WS6. I thought I had an LS1 Intake. Is it an LS1 or LS6? How do I tell the difference?
PostPosted: Fri Jun 18, 2004 8:28 am
01/02's came w/ the LS6 if I'm not mistaken.
PostPosted: Fri Jun 18, 2004 8:30 am
You are correct John! That is about a 5-10 HP improvement over the LS1 intake Hoch! ;)
 Post subject: LS6
PostPosted: Fri Jun 18, 2004 8:54 am
Ok, then what is the difference between and LS1 and an LS6 then? Or, what is the difference between my LS1 (with an LS6 Intake says you all) and an LS6 in a vette?
PostPosted: Fri Jun 18, 2004 10:01 am
The whole engine is different! The only thing the '01s and '02s got was the intake manifold, and maybe the cam (I think). That's it. And you needn't question the fact that you have an LS6 manifold- you do!
 Post subject: LS6
PostPosted: Fri Jun 18, 2004 10:07 am
Is the block the same?
PostPosted: Fri Jun 18, 2004 10:13 am
Quite different! Here's a link to some useful info!
http://www.idavette.net/hib/ls6/page3.htm
PostPosted: Fri Jun 18, 2004 6:22 pm
For us guys with the older F-Bodys the LS6 intake is a nice upgrade. It does not have the ugly EGR piping running into it. Adds about 10 or 15hp. Just a little extra to help out.
PostPosted: Sun Jun 20, 2004 10:41 pm
If you have a 2001, there is a slim chance you may also have the LS6 block, but not the heads and cam to go with it. If you are at one of the meetings sometime, I can look at your engine and tell you which block you have. I read about it a while back but can't remember where it was so can't tell you easily how to tell. The differences aren't major.
PostPosted: Mon Jun 21, 2004 7:33 am
I think I saw something about that on LS1Tech.
