Hawk
Post subject: kewl muffler system Posted: Sun Oct 10, 2004 10:31 pm |
ChrisV6
Post subject: Posted: Sun Oct 10, 2004 10:37 pm |
Uhh, it uses a turbocharger to reduce the noise...
Hawk
Post subject: Posted: Sun Oct 10, 2004 10:45 pm |
yup reduce the noise and adds about 130 hapees to the wheels however it has a whistle sound.
Post subject: Posted: Mon Oct 11, 2004 6:12 am |
Hawk
Post subject: Posted: Mon Oct 11, 2004 8:38 am |
they are claming it has a special impeller that spools up quick.
Post subject: Posted: Mon Oct 11, 2004 8:52 am |
Hawk
Post subject: Posted: Mon Oct 11, 2004 8:58 am |
LOL there is a right up im hot rodding that breaks it down. So why not use it in the normal setup, I guess it would make too much boost.
Post subject: Posted: Mon Oct 11, 2004 9:06 am |
Hawk
Post subject: Posted: Mon Oct 11, 2004 9:13 am |
130 Hapees on a stock LS1 that is the only bolt on.
Post subject: Posted: Mon Oct 11, 2004 9:23 am |
Hawk
Post subject: Posted: Mon Oct 11, 2004 10:15 am |
true but I think Nitrous would do the same thang then some.
Post subject: Posted: Mon Oct 11, 2004 10:23 am |
JackZ28
Post subject: Posted: Mon Oct 11, 2004 10:31 am |
I think 100 hapees per every 5 lbs of boost would be more accurate. The level of experience required to install that system is very minimal indeed.
Hawk
Post subject: Posted: Mon Oct 11, 2004 10:55 am |
That is a awsome muffler indeed. I am wondering how it would sound in da chicken.
ChrisV6
Post subject: Posted: Mon Oct 11, 2004 11:56 am |
Have a look at the "TURBO LS1 TUNNEL VIDEO" here
http://www.jlturbo.com/eyecandy.htm
Sounds pretty mean, also outside the tunnel.
What i don´t like is the oil feed line (and the entire turbo) that close to the ground... hitting something could get really expensive or loosing all your oil through the feed line within seconds/minutes...
And why didn´t they squeeze an intercooler in there somewhere?
The pressurized tube from the turbo to the intake is several meters anyway, so the pressure drop should be neclectable and you would get some extra power with that...
http://www.ststurbo.com
Hawk
Post subject: Posted: Mon Oct 11, 2004 12:09 pm |
They are saying that the air temperture cools by the time it gets to the intake. Makeing the need for the intercooler obsolete so you would be gettining 5-7 lbs of cool boost.
JackZ28
Post subject: Posted: Mon Oct 11, 2004 12:10 pm |
Post subject: Posted: Mon Oct 11, 2004 12:25 pm |
2slow
Post subject: Posted: Mon Oct 11, 2004 1:01 pm |
Joined: Sun Jul 04, 2004 11:34 pm Posts: 653 Location: Wolfsburg, Germany
Hawk wrote: They are saying ........
If "they" tell you to jump in the fire, would you believe that as well?
2slow
Post subject: Posted: Mon Oct 11, 2004 1:09 pm |
Roy wrote: Methanol is cheaper than Nitrous ,plus it has a higher octane rating than gasoline.
I would stay away from Methanol. The stuff is very hydrophobic (absorbs water out of the air) and then your car runs like sh*t. Worst however is that unburnt methanol has a habit of seeping past the rings and thinning out your engine oil. Nothing like a set of spun bearings to poop on your party.
Users browsing this forum: Majestic-12 [Bot] and 6 guests |
