Page 1 of 1
[ 10 posts ] |
jeejee
Post subject: ls1 inlet manifold Posted: Wed Sep 27, 2006 10:36 am |
can the inlet manifold be rotated 180 deg. ?
The throttlebody is then at the back of the engine...
Joeri
Post subject: Posted: Wed Sep 27, 2006 11:08 am |
jeejee
Post subject: Posted: Wed Sep 27, 2006 12:57 pm |
i don't want to damage any gaskets trying it yet.
if somebody knows at forehand it doesn't fit
Post subject: Posted: Wed Sep 27, 2006 1:30 pm |
jeejee
Post subject: Posted: Wed Sep 27, 2006 1:36 pm |
okee but does it fit ?
if you know it doesn't, i don't have to try
Post subject: Posted: Wed Sep 27, 2006 2:22 pm |
NXZ28
Post subject: Posted: Wed Sep 27, 2006 2:54 pm |
I saw one turned backwards on a RX7 with an LS1 transplant. It was in this months issue of Hot Rod. I think you can find the photos on 1320video.com Look in their pic section of Drag Week or Pump Gas drags. Good luck.
jeejee
Post subject: Posted: Wed Sep 27, 2006 7:14 pm |
hotrod ?
havn't received my issue yet, or is it the pumpgas drag issue ?
thanks.
was just curious if it would fit straight on or some mods would be needed..
ringram
Post subject: Posted: Thu Sep 28, 2006 9:28 am |
Would the map sensor be in the way of the TB?
Also I think Knock Sensor cables come out there too.
_________________ ----------- efilive distributor for europe richard(at)efilive.eu www.efilive.eu 2007 HSV R8 Clubsport LS2 M6, 7.2L, WCCH 400cfm LS7, Comp 227/243-113, Darton Block, Callies, Diamond, ACT Twinplate, 605ftlb, 625bhp
NXZ28
Post subject: Posted: Thu Sep 28, 2006 9:58 am |
The map sensor acutally plugs into the back of the intake manifold. So it would just be at the front of the motor then. I am trying to find the pics now and post them.
Page 1 of 1
[ 10 posts ] |
Users browsing this forum: No registered users and 2 guests |
