It is currently Mon Feb 02, 2026 7:35 am
 Post subject: ls1 inlet manifold
PostPosted: Wed Sep 27, 2006 10:36 am
can the inlet manifold be rotated 180 deg. ?
The throttlebody is then at the back of the engine...
Joeri
PostPosted: Wed Sep 27, 2006 11:08 am
You haven't tried it yet ?
PostPosted: Wed Sep 27, 2006 12:57 pm
i don't want to damage any gaskets trying it yet.
if somebody knows at forehand it doesn't fit :wink:
PostPosted: Wed Sep 27, 2006 1:30 pm
You won't damge the intake gaskets . There made of silicone.
PostPosted: Wed Sep 27, 2006 1:36 pm
okee but does it fit ?
if you know it doesn't, i don't have to try :roll:
PostPosted: Wed Sep 27, 2006 2:22 pm
Never tried it myself .
PostPosted: Wed Sep 27, 2006 2:54 pm
I saw one turned backwards on a RX7 with an LS1 transplant. It was in this months issue of Hot Rod. I think you can find the photos on 1320video.com Look in their pic section of Drag Week or Pump Gas drags. Good luck.
PostPosted: Wed Sep 27, 2006 7:14 pm
hotrod ?
havn't received my issue yet, or is it the pumpgas drag issue ?
thanks.
was just curious if it would fit straight on or some mods would be needed..
PostPosted: Thu Sep 28, 2006 9:28 am
Would the map sensor be in the way of the TB?
Also I think Knock Sensor cables come out there too.
PostPosted: Thu Sep 28, 2006 9:58 am
The map sensor acutally plugs into the back of the intake manifold. So it would just be at the front of the motor then. I am trying to find the pics now and post them.
