It is currently Thu Mar 26, 2026 12:21 am
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
 Post subject: LS1 Hot Cam
PostPosted: Sun May 27, 2001 3:07 pm
Well the camshaft is in and the springs are changed. I m currently waitng on new harmonic balancer, 2 pushrods and 2valve cover gaskets.
I buttoned it up as much as possible to do a test fire on it , and fire up on the first crank and idled just fine. Even though it made every one stop what they was doing to come over and look at the beast.
 Post subject: ...
PostPosted: Tue May 29, 2001 11:30 am
That's awesome Roy, I can't wait to hear it!!
PostPosted: Tue May 29, 2001 1:33 pm
Well Jack This waiting is killing me. I did do a test fire and sounded pretty good.
PostPosted: Thu May 31, 2001 6:28 am
I bet man, I've heard some mpegs of it on the 'net, and I know it does, especially with the resonator....
PostPosted: Mon Jun 04, 2001 11:40 am
Hey Roy, I forgot to ask, who put it in for you??
PostPosted: Tue Jun 05, 2001 5:26 am
Just me at the craft shop.
PostPosted: Tue Jun 05, 2001 10:09 am
How hard/easy was it Roy?
PostPosted: Tue Jun 05, 2001 11:13 am
It is a pretty straight forward application on the Ls1 I would rate it a meedium task for a firstimer that has downloaded all the "He said POOP" from the internet on camswaps on the Ls1.
PostPosted: Tue Jun 05, 2001 11:56 am
Danke fuer die info!!!
PostPosted: Wed Jun 06, 2001 11:06 pm
There is a great install guide at torquecentral.com
I have one on the way for my new (wife's old) car!!!
Paceparts sells them LS1 Hot Cam Kit for 418.xx shipped. May be a little more to an APO, but it includes everything you need including gaskets.
Another good package for a smoother idle is the LS6 cam.
The install is supposed to be pretty easy.
Good luck,
Jamey
PostPosted: Thu Jun 07, 2001 7:29 am
Thanks Jamey, so now what does the wife drive??
 Post subject: Update
PostPosted: Thu Jun 07, 2001 8:28 pm
Well the parts are in . So i dropped the oil pan and pulled the oil pump and put in the the timing cain and gears. I am about 25 % complete . It should be up and haunting the streets of Wiesbaden by Friday evening.
PostPosted: Thu Jun 07, 2001 9:38 pm
Congratulations Roy!!
PostPosted: Fri Jun 08, 2001 1:41 pm
Sweet Roy, wish I could hear it...
I will be putting mine in next weekend...by myself in my garage :) From what I've heard, you need a set of headers and to raise the rev limiter to really wake this cam up.
The wife now has a 2001 Chevy Blazer Xtreme. She is driving 55 miles each way to work, so wanted something with a smoother ride...plus I wouldn't let her put all the miles on the TA ;)
Later,
Jamey
PostPosted: Fri Jun 08, 2001 7:16 pm
jAMEY
If you need any impromptu advice on the install just email or in here. Goodluck on the install.
PostPosted: Sun Jun 10, 2001 2:36 pm
Is the ride up, Roy?
PostPosted: Sun Jun 10, 2001 2:50 pm
Fik nein, I still cannot locate a dam radiator drain pug .
Willis helped me out with the cap. I guess I will have to wait on the mail to get here . Who knows when that will be.
PostPosted: Sun Jun 10, 2001 4:10 pm
Shux man, I wish I could help you out.. When did you order it?
PostPosted: Thu Jun 14, 2001 9:50 pm
Well it is running now. It took about an hour to purge all the air out of my radiator . But that is good now. I ve put ahundred miles on it so far . I need to squeak the idle a hair to bring it up and to smoothit out a bit. As for power well I lost all my low end torque, but from the midrange it seems to hit pretty good. I see my mileage went to hell though. Got in a little scrap with a SLK 500 and intimidated
a m roadster. Time to go to the kill section.
PostPosted: Sun Jun 17, 2001 2:43 pm
Did you drill out the hole in the TB to smooth the idle out? They say it helps alot.
-- Jamey --
